P0358 code trouble...
Old Dec 3, 2014 | 11:44 AM
Dobster's Avatar
Default P0358 code trouble...
LS1 5.7L
I have changed the coil pack, plug wire, and spark plug. I am still getting the same trouble code P0358..??
I am not sure how to diagnose the wiring short?
I do know its the #8 coil.
I checked for a/c voltage across all 4 wires with the truck running. I got 13.8V from the Red/orange wire to all the other tree wires which are white, brown, black.
So I assume the red and orange wire is the power wire?
Switched to d/c v and got nothing?
I am really not good with understanding these.
So please be patient..
Thanks
Old Dec 3, 2014 | 02:27 PM
Russ K's Avatar
What year/model PCM is being used?
Russ Kemp
Old Dec 4, 2014 | 02:31 PM
Dobster's Avatar
1999 to 2002 LS1 is written right on the PCM
Its been running fine this is a new code!
Thanks for helping...
Old Dec 4, 2014 | 04:48 PM
Russ K's Avatar
Russ Kemp
Attached Thumbnails P0358 code trouble...-206010500.gif   P0358 code trouble...-169400301.gif   P0358 code trouble...-92892106.gif
Old Dec 4, 2014 | 04:55 PM
Dobster's Avatar
I pulled the harness from the pcm and ohmed out the wires from the #8 plug-in to the harness plug in #66, to white #61 to brown, red/orange wire is 12V and black is ground.
All seems good?
Old Dec 4, 2014 | 09:10 PM
Dobster's Avatar
I clear the fault codes and restart the truck. It runs perfect for a few minutes I run a scan for fault codes and its clear, then gradually..... starts to misfire..... I run code faults and get P0358 and P0354
here is the fault as I emailed it to myself...
Vehicle Manufacturer: Chevrolet
Vehicle Calibration ID: 12202088
09357744
0936
Current Fault Log
P0354: Ignition Coil "D" Primary/Secondary Circuit
P0358: Ignition Coil "H" Primary/Secondary Circuit
P0650: Malfunction Indicator Lamp (ML) Control Circuit
Pending Fault Log
ECU reports no pending faults
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
End of report.
Dobster's Avatar
Here is the freeze frame...
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Freeze frame information:
Engine Load = 4.706 %
Engine Coolant Temperature = 177.8 °F
Fuel Trim Bank 1 Short Term = 0 %
Fuel Trim Bank 1 Long Term = 17.188 %
Fuel Trim Bank 2 Short Term = 0 %
Intake Manifold Pressure = 3.916 psi
Engine RPM = 1,667 rpm
Speed (OBD) = 0 mph
Mass Air Flow Rate = 108.85 cfm
End of report.
Old Dec 4, 2014 | 09:27 PM
Dobster's Avatar
I found in the #8 the spark plug was comletely different than the rest...
It is a NGK-R tr6 v-power
all the others are AC delco 19256067 41-993...
I will get a delco tomorrow...
I know I posted a lot of information on this tread...
I just hope the right person takes a look and is able to help!
Doby
Old Dec 5, 2014 | 06:03 AM
Dobster's Avatar
I moved the odd spark plug to #4 cleared codes and now i get a fault code for P0354?
Whats odd to me is I still get the fault code for P0358 even with the correct spark plug????
Is the PCM just turning off the fuel injector due to the past fault code????
Can the PCM not completely clear the code?
Old Jun 17, 2020 | 09:26 AM
austinws6's Avatar
Did replacing the spark plug and clearing the codes ever solve your problem or did something else come up?
Old Jun 17, 2020 | 10:40 AM
Dobster hasn't been here in over 5 years.
Old Jun 17, 2020 | 12:17 PM
austinws6's Avatar
Alrighty, thanks.
