Need help with reading logged runs, HPT
Old Jan 7, 2015 | 09:17 AM
RENE'S RAGE's Avatar
Default Need help with reading logged runs, HPT
I've got some runs logged with my HP Tuner.
Just learning how to read them. I'm wanting to pull up a chart for my RPM's.
All I can find is in the RPM gauge display. And it reads so fast I can't keep up with it.
I'm wanting to see where the converter flashes to off the line and shift drop rpm's between gears.
If I had a chart, graph where I could pause it at, that would be great.
I'm sure there is one, just don't know how to pull it up.
Thanks
Old Jan 8, 2015 | 07:20 AM
Help!
Old Jan 9, 2015 | 08:39 AM
key4's Avatar
I'm new at it too but on your logs at the top toward the right of the screen you should have a pause button. Also you have a column with a number in it. You can lower it to slow your frames down. Hope this helps
Old Jan 9, 2015 | 09:33 AM
Thanks, I'll look into.
Old Jan 9, 2015 | 09:55 AM
key4's Avatar
Who tunes your car? You from memphis right?
Old Jan 9, 2015 | 01:58 PM
Yeah Memphis, Josh @ DynoSpeed. I bought a HPT and trying to learn more about it.
It has a Dyno tune in it now, we haven't tweak on it at the track yet. Going to this year.
Old Jan 10, 2015 | 07:52 PM
rpturbo's Avatar
If you look at my screen shot, on the top bar, almost exactly in the middle, you will see a box with the number 10 and a up/down arrow. Just to the left is a stop, pause and play button. You click that play button when you want to play a saved log, you can click the pause button at any time, and if you look in my shot, there is a white line, you can drag that across any segment of this frame set for a specific spot's data. Hope this helps.
Attached Thumbnails Need help with reading logged runs, HPT-hp-tuners-scan-shot.jpg
Old Jan 12, 2015 | 10:03 AM
Thanks, I'll look into that also!
Old Jan 12, 2015 | 06:50 PM
How do I get the RPM on the graph all I have on mine is MAP, Advance Timing, TP, INJ, O2, and LTFT and STFT. The RPM's show on my gauge's and the primary table so I assume that its being read but for some reason isnt on the graph.
Old Jan 12, 2015 | 07:00 PM
2xLS1's Avatar
File > Open Config > Default Imperial.cfg
Have you looked at all the demos here?
http://www.hptuners.com/forum/showth...iles-and-Demos
Old Jan 13, 2015 | 07:49 AM
I'll check it out.
Thanks everyone with the help, we're getting there.
My wife, Rene', is doing all this computer work, I'm not computer savvy!
Car is tuned in CLSD. Hoping to learn how to tweak the tune this year.
Old Jan 15, 2015 | 05:33 PM
rpturbo's Avatar
Lots and lots of reading. PM me your email address, and I will send you some info I have accumulated.
Old Jan 17, 2015 | 01:29 PM
Thanks guys, finally got all the charts pulled up.
