Turbo Build Almost Done,, Now how to get to Tuner??
Single Turbo Build Almost done on car,,, question is the Cold side on kit is set up for Speed Density tune and car is currently tuned on MAF tune,,, All i need is to be able to get car to start and get on and off trailer to get into tuner.... Can i just take MAF off and hook up kit,,, and install the 2 Bar MAP sensor and be able to drive on and off trailer,, then get tuned for SD?? Another way would be leave the MAF on bellow hooked to throttle body, then remove when i get to tuner and tune SD..... If i add the 2 bar MAP what will that do? Prior to getting tuned... how would you do it..
