intake/headers tune
Old Apr 26, 2015 | 10:00 PM
EricZ28/SS's Avatar
Default intake/headers tune
I have a 2000 camaro ss m6. I bought the car completely stock and now I put an slp lid and hooker 1 3/4 headers with a 2.5 inch exhaust. Car at idle runs at 14.6-14.8. What would be a some things to change to accommodate for the intake and headers?
Old Apr 27, 2015 | 01:14 AM
AdsoYo's Avatar
you mean as far as the calibration? 14.6-14.8 sounds right on the money. Are you wanting to lean out idle?
Old Apr 27, 2015 | 05:05 AM
EricZ28/SS's Avatar
I was told I have to tune the car for the headers but the car runs exactly how it should without a tune. Souls I even have to worry about tuning anything?
Old Apr 27, 2015 | 05:24 AM
HCI2000SS's Avatar
A tune is going to help regardless
Old Apr 27, 2015 | 03:48 PM
2xLS1's Avatar
As is often the case with MAF vehicles. Just don't tell anyone. Maybe some codes will set for any emission systems you deleted. It will benefit from a tune as would a stock vehicle though. Just doesn't always require a tune to run OK.
Old Apr 27, 2015 | 05:30 PM
EricZ28/SS's Avatar
I'm trying to all what would be things to change in my tube to maybe run a little richer and get a little more performance out of my mods?
Old Apr 27, 2015 | 09:11 PM
2xLS1's Avatar
Closed loop (idle, part throttle) fueling is going to run at stoich. That's how closed loop works. WOT fueling on a 2000 F-body is pretty rich in the stock tune commanding a 11.76 A/F at all RPMs in PE. You could benefit a little by leaning that out a bit. WOT timing is already pretty good on a 2000 also. You would notice a big difference with some good trans tuning and getting rid of torque management.
Old Apr 27, 2015 | 09:33 PM
EricZ28/SS's Avatar
You're saying disable torque management and tune the translation how? Mine is a 6 speed car
Old Apr 27, 2015 | 10:25 PM
2xLS1's Avatar
Didn't notice that. No tuning or Tq Management on a manual trans. All you would tune is the engine. You can also disable the skip shift, adjust the fan turn on/off temps, and turn off any emission codes. That's about it.
Old Apr 28, 2015 | 06:58 PM
EricZ28/SS's Avatar
So at idle the car is between 14.6-15.3, what can I change to keep it in the 14s at idle preferably closer to mid 14s afr?
Old Apr 29, 2015 | 01:08 AM
eaglegoat's Avatar
For what purpose?
