07 Z06 startup tuning
Old May 17, 2015 | 02:55 PM
Goinbyyabig's Avatar
Default 07 Z06 startup tuning
I am trying to get this car to cooperate, but am getting frustrated. It starts good cold, no throttle needed, and idles fine. Only on a hot restart do I have an issue. I have increased and decreased the cranking FA, as well as the cranking VE and cranking airflow. Tuning it changes what it does, but unless you press the accelerator pedal, it doesn't fire up warm. Touch the gas and it fires right up fine. The rest of the tune is really quite good, just need to try to resolve this. The car has Mast 305 heads and their cam intended for them, Kooks long tubes and cats, BB exhaust, CAI, larger MAF. This is a retune after heads and cam. Any thoughts where I should experiment?
Old May 17, 2015 | 05:31 PM
mrvedit's Avatar
Moderator
Did you try adding to the Idle->Base Running Airflow at the temp you are having starting problems? Try adding "2.0" there.
Old May 18, 2015 | 10:19 AM
I should correct myself. The car doesn't want to start, warm or cold, without some throttle applied. It fires up great with maybe 10-20% throttle and idles great on it's own. I did try the min. idle airflow, from .5 increase up to 4.0 and it doesn't improve. More cranking FA (fuel) More cranking airflow, more cranking spark, less cranking VE, I feel like I'm running out of options. Probably a table I don't understand or know exists. Any other thoughts?
Old May 18, 2015 | 10:57 AM
LSX Power Tuning's Avatar
Post up your tune.
Old May 18, 2015 | 12:09 PM
Not sure how to post it here. Do you want an info log? It won't allow me to copy/paste. I'd gladly pay for some assistance if that helps.
Also tried to make it an attachment, but the file is a bit too big, so it again, won't allow it.
Old May 18, 2015 | 04:24 PM
mrvedit's Avatar
Moderator
Also give us your cam specs.
A log file showing the IAC values during startup and immediately thereafter might be useful too.
Old May 18, 2015 | 05:23 PM
Cam is a Mast 912-103.
Lobe separation is 114.1
Overlap 25.1
Intake:
Centerline 110
Duration 246.2
Valve lift .658
Exhaust:
Centerline 118
Duration 260.2
Lift .666
Unable to provide IAC data since it doesn't have one. I have fiddled around and have it starting warm, barely, with the VE, Cranking airflow, and FA tables. Once it catches, it's happy, but I know they hate big cams.
Thanks for the responses!!
Old May 19, 2015 | 04:52 PM
email the tune to the email in my sig and I'll take a look
Old May 21, 2015 | 09:02 PM
I just want to publicly say thank you to LSX Power Tuning for the look over and advice on how to correct this issue. I did what he suggested and have a happy starting car, once again! Great call for the first try on what to change and how much to change it. I will be remembering this in the future.....
Old May 22, 2015 | 04:32 PM
roastin240's Avatar
Can you post up what needed to be changed? This could help others that run into the same issue in the future by searching the forums. Glad its running now though.
