MAP sensor tuning
Old Jun 1, 2015 | 11:01 AM
82streetshow's Avatar
Default MAP sensor tuning
I have a swap vehicle with an ecm from 02 Silverado in the vehicle and went to a hi-ram holley intake which requires ls3 style map sensor. I know this sensor is totally different my question is, can hptuners tune for the different style or do I need to find a way to make my MAP sensor fit?
Old Jun 1, 2015 | 01:46 PM
redtan's Avatar
MAP sensors are MAP sensors...they measure manifold pressure. Not much variance there.
Now a MAF for example is a different story as those are calibrated differently, but the MAP not so much. As long as you get a reading in the scanner you should be good to go.
Old Jun 1, 2015 | 02:08 PM
2xLS1's Avatar
kPa range and offset can vary greatly between different MAP sensors. You can make the original MAP sensor work with a piece of hose. Just tap into a manifold vacuum source somewhere. Might require some kind of hose barb fitting.
Old Jun 1, 2015 | 02:22 PM
gofastwclass's Avatar
HP Tuners can adjust the MAP sensor parameters to match the sensor you add. I'm using an LS3 sensor on a P01 (AKA 411, red / blue) PCM.
Old Jun 1, 2015 | 03:50 PM
Okay Thank You, Im using same PCM and I am currently building the harness for the engine and wanted to make sure HPtuners could compensate for the different sensor but couldn't get ahold of my tuner to verify.
