Question tuning by lambda error
Old Jun 19, 2015 | 12:03 PM
edge04's Avatar
wow that function also throws odd readings. will have to mess with it.
my AFX box first shows 2.0 when it power ups then counts down. It displays 1.08 with key on and not started. I thought this was correct as it will never display 0 or 5 volts?
Originally Posted by eaglegoat
Winner, winner, chicken dinner!
Bonus tip: I use 14.12 for e10 stoich
Edit: I just saw your other thread and that you're running an e38 controller. For the E38 and newer controllers commanded EQ is the same as commanded lambda. In that case you want to use
100*([AUX.20121]-[pid.68])/[pid.68]
Old Jun 19, 2015 | 01:12 PM
eaglegoat's Avatar
It sends the voltage thru the signal to hpt. If you watch it count down from 20 to 0 at some point you should see 1 on your hpt lambda display. If you don't then most likely you have a bad ground.
Old Jun 19, 2015 | 04:08 PM
edge04's Avatar
all good, displaying the 1
but that function doesn't work, well doesn't have me commanding 1
Old Jun 19, 2015 | 04:20 PM
eaglegoat's Avatar
What's the commanded eq when you're warmed up?
Old Jun 19, 2015 | 04:53 PM
edge04's Avatar
key on engine off 15.xx
Engine on from -3.xx to 4.xx
I have Commanded EQ Ratio (SAE) as well as Air Fuel Ration Commanded Hi Res in my primary table
Old Jun 19, 2015 | 05:56 PM
eaglegoat's Avatar
The eq ratio, [pid.68], is showing up 15.xx or -3.xx to 4.xx? Something is broken.
Old Jun 19, 2015 | 06:21 PM
edge04's Avatar
almost like its displaying A/F
here is a quick log with the key on engine off
File Type: hpl
Old Jun 19, 2015 | 06:23 PM
edge04's Avatar
function
Old Jun 19, 2015 | 08:12 PM
eaglegoat's Avatar
I'm at work. I'll check this out later.
Old Jun 19, 2015 | 08:13 PM
eaglegoat's Avatar
function
That function is showing lambda error.
Old Jun 19, 2015 | 10:27 PM
edge04's Avatar
ok. I thought you were suggesting I change my function for commanded lambda from [PID.6001]/14.20 to something else. But now I'm guessing you are suggesting I change my lambda error function??
Old Jun 20, 2015 | 01:27 AM
  #32
eaglegoat's Avatar
The lambda error function you showed in the picture is correct.
On a gen 3 commanded lambda is (1/[pid.6010]) on an e40 it's (1/[pid.68]) and on e38/e67+ it's just [pid.68].
Old Jun 20, 2015 | 10:30 AM
  #33
edge04's Avatar
Got it. All set
Been tuning the VVE with bluecat and also using a COS with real VE. I notice that I can change the MAP axis points but not the MAF on the COS. Not a big deal just a little more work is all.
Thanks!
