Have you ever heard of this??
Car will start and idle just fine but no throttle response from DBW. Throttle blade will flutter when you turn the key, but that's it. I have gone through the wire harness over and over. Tried a different pedal...no change.
It all worked at one time. Right after the engine was placed on the frame, we mocked everything up, reflashed the PCM with HPTuners and fired it up. It all worked. I have a video of it. But, I did notice that it would drop the peddle operation after sitting a while and it would have to be reflashed again to get peddle operation back.
Here's what I think: The PCM has bad memory. You can flash a tune into it and as long as it stays connected to power its ok. But, if you disconnect the battery it loses a portion of the tune, specifically the DBW portion. I no longer have access to HPTuners like I did in the past so I can't really prove this, but I have no other explanation.
I am open to any comments. Has anyone ever heard of this? Is there anyone that has a way to test my PCM and/or TAC module? Are there any other tests I should perform to troubleshoot this? Do I bite the bullet and buy HPTuners and if I do that where do I find a Corvette tune?
Is there communication between the TAC module and PCM. If not, a U0107 DTC will set? The TAC module will disable throttle control if it cannot communicate with the PCM.
Any other DTCs?
You are running a 12200411 PCM correct?
The pedal will not operate the throttle in way at this point. It has in the past but not know.
Place your bets.
Looks to me that you would just match the ends pin for pin. WRONG! Take a look at the actual schematic (and its from the same website):
Everybody see what I'm getting at? This has got to be my problem. I'm 99% sure I built the cable matching pin for pin. A to A, B to B, C to C etc... I'll be checking this when I get home tonight.
Back to the drawing board. I have some sort of intermittent connection I guess. Very frustrating to say the least.
You would have codes for pedal circuits if the pedal wiring was messed up.
I made sure I have constant voltage at the PCM, pins 20 and 57 on the blue connector. Ignition voltage at pin 19 blue connector and TAC module. Grounds are good.
Thoughts?
It only throws the code when I turn the key to off. Is the tac module supposed to have battery or ignition voltage?
