Maf issue when logged?
Old Jul 14, 2015 | 11:19 PM
Firecat700RR's Avatar
Default Maf issue when logged?
Simple maybe dumb question? When logging with hptuner the round maf guage that reads lbs/min flutters or doesn't stay steady when rpm's are climbing up through at wot. It climbs up to about 49 lbs/min at peak but is it normal for it to not be steady climbing up through the rpm's at wot?
Old Jul 15, 2015 | 07:50 AM
RedHardSupra's Avatar
try cleaning your air filter
Old Jul 15, 2015 | 08:18 AM
gmorris's Avatar
Have you movd the maf or changed the intake at all? I get some fluctuation but it's likely turbulence in the intake causing the readings to move around. If you don't have one a honeycomb flow straightener may help or move the mafe further from the filter or any elbows.
Old Jul 15, 2015 | 05:04 PM
New air filter slp lid on 99 z28
