Hard start when warm
It fires right up and runs perfect most of the time, but occasionally once it's warm and been sitting it will either fire half heartedly and sputter out real quick or not want to fire off at all. Kinda acts like a flooded car would, have to crank it for about 10 seconds and then it will light off and run fine but idle a tad high for several seconds.
I've tuned VE, MAF, and the running airflow tables for park/n and in gear. Leaning towards thinking it might not have enough airflow in the warmer sections of the idle airflow tables but wasn't sure if there was some other place that would be best to look before I start adding airflow there.
Any thoughts are appreciated
I don't recall having this problem prior to the swap from ls1 to ls2. At first I thought it might have been related to the cam sensor extension harness but everything seems fine there. Not much changed in the tune itself during the swap other than touch ups on VE, MAF, and redoing the idle airflow. Even kept the same timing table.
