Crank sensor problems
Old Jul 28, 2015 | 08:40 PM
peteggl's Avatar
Default Crank sensor problems
Having some trouble with my car not starting, it has 60 psi at the rails when trying to crank. I have no spark or injector pulse at all, and I have replaced the crank sensor and cam position sensor both, all wires to both check out good and all of my grounds are checking out good, is there anything at all that could cause this besides the crank sensor? I'm not throwing any codes, and I have no clue where else to go other than it possibly being the PCM itself, any help is appreciated
Old Jul 29, 2015 | 03:29 AM
peteggl's Avatar
Don't know who moved this but I really doubt this is the right place...
Old Aug 13, 2015 | 02:04 AM
LilJayV10's Avatar
Is the tach moving when you crank it over?
Old Aug 13, 2015 | 06:00 AM
joecar's Avatar
Check the wiring and terminals in the connectors (check PCM connector/socket for water intrusion).
Check crankshaft endplay.
