Hard start and randomly dies.
And each time after about 30 seconds it dies. Not like stalling out, but like I turned the key off. Then it will fire right back up and will be fine.
Last time it happened after searching I tried swapping relays with the ignition one. No change.
I dont think it is vats since it cranks and i get no security light.
Any ideas? Does this seem like crank position sensor?
Thanks
David
your delay start sounds like its not getting enough fuel pressure but eventually after continuing to crank it you build up enough pressure to fire but not sustain itself. Though it not choking out when it dies does suggest it might not be fuel related. there is a port on the fuel rail to plug in a fuel pressure gauge and I think I would start there before digging into sensors and such.
From searching on here wouldn't that point to the crank position sensor?
David
