Cylinder wash out with injector size
So I have a 60k mile car that I just put heads and cam in. I upgraded to 42 lbs injectors. So I got a mail order tune and started the car. Had horrible excessive fuel and car would barley run once in closed loop. It would run if I kept giving it more throttle but died every time I tried to get it to idle. Found out the injectors in the tune were set at stock. So I was dumping tons of fuel in the motor. I would say it even ran for more than maybe 5 min. It was open header too so it was pushing the extra fuel out the exhaust. Is it possible that I could have washed out a cylinder? Don't think I did but wanted some opinions?
No harm is done with 5 min of running the engine. It needs longer that that to damage it.
I wouldn't drive it that way tho. Install stock injectors and drive to the tuner, then change injectors there.
