Good wideband?
Old Sep 21, 2015 | 11:36 PM
Snap-On's Avatar
Default Good wideband?
I've done quite a few searches, but the posts were a little old. I'm hoping to get some insight as to which current wideband are the best for the money. What is the best bang for the buck widebands?
Also I'll be using hp tuners. I can't decide if I should get one with, or without the guage.. thanks
Old Sep 22, 2015 | 12:59 AM
eaglegoat's Avatar
Ballenger AFR 500
Old Sep 24, 2015 | 11:27 AM
LetsRide's Avatar
I went with Innovative gauges prices aren't to bad.
Old Sep 24, 2015 | 11:58 AM
Rise of the Phoenix's Avatar
I really like my AEM uego.
Old Sep 25, 2015 | 02:07 PM
Snap-On's Avatar
I went with ame uego... I'll see how well it works lol
Old Sep 25, 2015 | 02:18 PM
I think you'll be happy with it. The install is pretty easy and straight forward too.
Old Sep 25, 2015 | 03:48 PM
Snap-On's Avatar
Do you happen to remember if yours came with 3 different guage faces? Mine only has a white a/f face and a black Lamda scale face. It also looks like mine was supposed to have an o2 bung to weld in as well.
I'm curious as the box was previously opened
Old Sep 25, 2015 | 03:58 PM
joyridin''s Avatar
Can you wire the AEM set-up into HP Tuners?
I know mine had a black face and a white face. It also came with a black and silver outside ring. Mine also came with the bung. I tuned out my 02 sensors (OLSD) so I didn't need it.
Old Sep 25, 2015 | 10:52 PM
Drj8787's Avatar
I just went threw the same thing ( looking at widebands) I ended up buy the apsx d1 with display. It was $114 shipped I figuered I'd try it out. It's made in Ohio and is very basic and lacks good instructions for programming the settings, but they have info on the web about it just need to look at it. I guess if that's what it takes to keep cost down that's what they do. Also the wire harness isn't very long but I believe it will be just barley enough the way I'm wiring it.
I just got it wensday and have already got the wiring figured out to use a stock O2 connector to power it up and utilize the NBo2 output also. I've only tested that it powered up so far, I will be installing it permanently in the morning and will let u know what I think. I also will be logging threw the egr input to the pcm with hpt will let u know how well it works
