EGR to AFR with HP Tuners
2000 Trans Am
Trying to make my innovate lc2 wideband read AFR on my HP tuners through the EGR.
I have the output 1 going to the gauge on the wideband and it works perfect. I have output 2 going to the egr + on the pcm and it wont read on my HP tuners. My tuner setup the config on hp tuners so that is all good. Just trying to figure out what im missing. Do I need to ground a wire or something?
Thanks for the help.
I have a '99 and it's pin out #55, EGR Pintle Position Sensor Signal, brown wire. On the blue connector.
The EGR ground wire is #41, EGR Pintle Position Sensor Ground, black wire. On the blue connector. You may need this ground wire for your particular Wideband. I have an AEM Wideband and don't use the ground pin out.
