Tuning advice
Old Oct 25, 2015 | 02:07 PM
Ls6z71's Avatar
Default Tuning advice
Have a 01 z71 Silverado just swap a 04 ls1/6 in it with all truck accessories. Also installed headers and egr delet question is how bad should it run befor tune. Starts up idels fine when driving has zero power won't get out of its own way?? Any one done a swap similar ??
Old Oct 25, 2015 | 02:40 PM
sddel40's Avatar
Check fuel pressure [.
Old Oct 25, 2015 | 03:37 PM
Ls6z71's Avatar
Will do that's was nest step and see what codes it's throwing
Old Oct 25, 2015 | 08:01 PM
mrvedit's Avatar
Moderator
My daughter recently bought a '03(?) Suburban with LQ4 engine. She got a great price because it was wayyyy down on power. Turned out to be a clogged catalytic converter.
Old Oct 25, 2015 | 10:13 PM
Darth_V8r's Avatar
Moderator
That burned me on a dyno. Quite a lot.
Old Oct 26, 2015 | 07:17 AM
Ls6z71's Avatar
Yeah I'll be going with a ""off road y pipe" but I can't see them being clogged swap took about a month and never had issue with cats be for swap
Old Oct 26, 2015 | 07:18 AM
Ls6z71's Avatar
Just curious how bad it should run befor the tune ecm still thinks it's a 290hp 5.3 not the ls1/6 that's in now first time doing this swap
Old Oct 26, 2015 | 08:57 AM
Darth_V8r's Avatar
Moderator
I don't know about trimming itself, etc, but a quick look at the stock tables on my 04 5.3 suburban vs my stock LS1 f-body tunes, and they aren't even close. The 5.3 is way down on timing. The VE's are way different as well.
So, if you're still on your stock tune, it probably will feel sluggish - low on fuel and timing
Old Oct 26, 2015 | 06:23 PM
Ls6z71's Avatar
Ok yeah I'ma check out everything on my end fuel pressure codes ect. But sure tune will get it right
