Id850 stft
Old Nov 25, 2015 | 04:22 PM
maroonls1z's Avatar
Default Id850 stft
I installed a set of id 850s and put in the injector data supplied and my stft are now in the 30's. What did i do wrong?
Old Nov 25, 2015 | 04:29 PM
maroonls1z's Avatar
correction thats -30's. here is both the tunes i am working with. I put the data in the same on both
File Type: hpt
File Type: hpt
Old Nov 27, 2015 | 10:52 AM
maroonls1z's Avatar
Someone please take a look at my tune and tell me what i missed?
Old Nov 27, 2015 | 11:56 AM
2xLS1's Avatar
Using the beta version on a vehicle that doesn't require it keeps a lot of people from being able to look at it.
Old Nov 27, 2015 | 06:16 PM
maroonls1z's Avatar
Ohh i didnt think of that, ill repost. My flex fuel tune only runs in beta so i did the other on in that
Old Nov 29, 2015 | 10:49 AM
maroonls1z's Avatar
here is the tune in non-beta, any assistance is appriciated
File Type: hpt
Old Dec 8, 2015 | 05:38 AM
maroonls1z's Avatar
Anyone?
Old Dec 8, 2015 | 08:06 AM
maroonls1z's Avatar
Can someone please take a look and see what i missed
Old Dec 8, 2015 | 03:21 PM
maroonls1z's Avatar
2 wks and no help
Old Dec 8, 2015 | 04:11 PM
LSX Power Tuning's Avatar
You have entered the data that you posted correctly. Have you changed your VE or MAF tables? What are your mods?
Old Dec 8, 2015 | 06:07 PM
maroonls1z's Avatar
At the time i was doing these it was just long tubes and full exhaust
Old Dec 8, 2015 | 06:09 PM
maroonls1z's Avatar
Since then i have put in a built 434 that im hoping to start up tomorrow and was hoping to use those injectors but now im wondering if i should just put in the ls7 ones i have and copy the data over from a zo6 file
Old Dec 8, 2015 | 06:16 PM
maroonls1z's Avatar
I was really just hoping i missed a table or needed to scale the data
Old Dec 8, 2015 | 10:12 PM
2xLS1's Avatar
Supposedly ID supplies some of the best injector data in the industry. If you input their data for their injectors and your trims are off that much there are other parts of your tune that need to be corrected.
Old Dec 9, 2015 | 06:31 AM
statesman's Avatar
I'm guessing that your injectors are actually ID1000's. Try putting in the ID1000 injector data and see what your trims look like.
Old Dec 9, 2015 | 06:37 AM
maroonls1z's Avatar
The physical dementions dont match the 1000s. The 850's and short while as far as im aware the 1000's are long. If i had a factory tune and all i changed is the injector data and my fuel trims were fine before then i dont know whats going on and thats why i posted. Should have been very simple. I just wanted to install the real quick before i put the new motor in but the didnt work right for some reason
Old Dec 9, 2015 | 06:48 AM
statesman's Avatar
If you're running rich then the flow rate is wrong. You need bigger numbers in the flow rate. Try multiplying all your flow rate values by 1.15 and see what the trims look like.
Old Dec 9, 2015 | 07:17 AM
maroonls1z's Avatar
At this point its too late for that since the new motor is in and i am going to have to work up a new tune entirely. Ill start with my ls7 injectors and then swap the id850's back in. I just cant figure out why its wrong. The spread sheat will scale its self so its super easy to adjust the data. I just should not have to
Old Dec 9, 2015 | 07:42 AM
statesman's Avatar
Okay, do that.
GM used two different MAF sensors... one which could read up to 439g/s and the other which could read up to 512g/s. Looking at your tune file I see that you've got the 439g/s MAF sensor.... you might end up pegging that MAF.
Old Dec 9, 2015 | 08:30 AM
maroonls1z's Avatar
Okay, do that.
I have a 100mm one from texas speed i plan on running but thankyou
