please help. idle/staying running problem.
Old 06-10-2004, 11:51 PM
LARRY01Z28's Avatar
Default please help. idle/staying running problem.
ok here it is. ive got a 2001 camaro. 224/224 .581/. 581 on a 112lsa cam and tea heads stage 1.5. i just took the 6 speed out and put a t-400 in it. when i tune the car it runs perfect for about 15 start ups. then after that it just gets worse and worse. like it doesnt want to stay running? anybody got any suggestions? i dont want to have to tune my car every 4 days. lol TIA
Old 06-11-2004, 12:04 AM
383838's Avatar
Most likely it's the LTFT's being off and/or VE tuning. For the first start ups the PCM does not have open loop LTFT's learned so everything will run fine. If there is an issue, such as a major exhaust leak, it will show itself more and more as the LTFT's will read false lean.
Old 06-11-2004, 12:21 AM
LARRY01Z28's Avatar
ok, ive got no exhaust leaks. ill look into the LTFT's. thanks alot. ive got ls1 edit so ill try to play around with it. thanks a millon.
