PCM Experts please help
https://ls1tech.com/forums/generatio...arly-98-t.html
Peter
If you are not doing the re-pinning yourself I would imaging paying someone labor to do it and the tuning part would exceed the cost of another 98 PCM.
The PCM isn't even connected directly to the fuel pump, the pcm is connected to the fuel pump relay that turns the fuel pump on. If you shorted the fuel pump power circuit the only possible result would be a blown fuse.............................................. ................I suggest you are either being bsd or complete morons are working on your car.
2 new fuel pumps shorted??? You realize EVERY PUMP is tested before it leaves the factory with a high voltage megger?
I wouldn't put another pcm in that car until ALL the engine wiring is checked out properly.
If you need help diagnosing this I'm willing to try and walk you through it. Sorry but what they are telling you is so far out there Elvis maybe working on your car. Good Luck
