Surging when Coasting
We need to figure out what's causing you to need so much airflow. Your VE table doesn't look quite right to me... maybe a symptom of bad injector data, but I don't know if that's enough to cause this.
See if you can get a log for me.
Plan to do some WOT tweaking and then hit the 1/8 mile in the next couple of weeks.
I've been messing with the timing. I added timing in the 1400 cell from 22 to 26 to get it to smooth out low throttle bucking in the .20 to .32 airmass cells. It helped.
However, for decel, I don't know which table it's pulling from. I've adjusted both the idle spark advance tables below .20 and the main spark tables below .20, but it doesn't always seem to pull from main spark. When I let off the gas, it seems like it pulls from the idle spark table, even above the idle spark routine cutoff mph.
Is it taking a mix of them? I put main spark at 26 in the lower airmass cells and put idle at 22 across the board... and low and behold, it's 22 degrees on decel. Is it supposed to pull from the idle table? Or a mix?
The car seems to like 22 degrees off-throttle. I got a noticeable reduction in the bucking. still some cam surge, but damn, I could so live with it like that.
One final thing - in CL at least, it still wants to bounce off idle returning to a stop. Not much mind you. I zero'd out the 400 cell of the cracker table. Still is a bit wobbly going back to idle. In OL it doesn't seem to happen as pronounced. Any ideas?
Btw, thanks to statesman for giving me the idea to lower the decel timing below spark timing (though I have that question on where it's pulling the timing) and to zero out the cracker 400 rpm column.
And finally, I took out airflow from the base airflow. I had run RAF, but it was still too much airflow. I had around 5.1g/sec... took it down to 4.8g/sec and that helped in the operating temp range. That also allowed the IAC counts to lower down a little bit. The key there was the A/C. When I turned the A/C on, I was adding significant airflow to the model. So I logged A/C airflow with Cracker and Throttle plus total airflow. Overall, the drivability got worse with A/C on, so I started taking out airflow and that helped a lot.
The point is, airflow and timing changes affect one another. So it takes time to just try one and see what happens. It also affects A/F. Now that I got the timing pretty well set, the airflow model came together and helped. A/F changed some, but it was only be 1-2%, so I'm okay with that as CL can compensate for that. Also, surprisingly, the bank-to-bank differences were less than 5% which was better than it was before. So getting it all aligned, made everything work better.
