HPTuners tuning question
I've been tuning my car via months and months of reading and absorbing. Data logged with a W/B and have the tune pretty much dialed in terms of drivability and stability.
This is a fresh build 347 with all the goodies mid-sized cam and aftermarket heads.
Idle, VE, injector data, a/f
But what other features really need to be looked at?
Any help is appreciated.
If nothing other than the features that I've mentioned above, are there any real benefits?
A dyno is particularly useful for tuning, because you can load the car up, get an independent AFR measurement, measure how spark changes affect performance etc. for example - did you get more power at 25 or 27 degrees timing? With a dyno you can answer that. My car for example makes its best power at 24 degrees advance, but common internet knowledge says 27 is optimal. Without a dyno I'd be at 27, not 24.
However, you've left off the most important item - the skill of the person doing the tuning. A good tuner can do in an hour or two what will take an average hack like me over a month to do. And will be less likely to blow the motor or brick the computer.
Hope all that helps
Hope all that helps
Numbers do not matter in this case as the car is a driver and runs fairly well. I've had enough ls motor based cars to know what kind of power it's making.
In the past I've used Alvin who is local to me and a very knowledgeable tuner. But this was my first tuning project with HPTUNERS and I feel confident in what I've accomplished. Drivability is very good other than the fact the car would love more gear.
However once more gear is added it will become less usable power. 6speed from 3:42 to 4:10 = Tire shredder☺
As mentioned above the next step for you would be Dyno WOT pulls, to dial in your upper rpm.
Other things to look into would be transmission stuff if you arent running a manual. Like checking your torque management, and looking at your Power enrichment. Again this is all for dialing in WOT power. If you arent concerned with getting every bit of power out of it.
