Cammed LQ4/4L80E Tune Critique
I have a 1970 Chevelle I installed a 2004 LQ4 in w/ a 4L80E
Tune attached, I also attached the scan log of the 1/4 mile run
Mods:
3000 rpm stall converter
232/240 .595/.608 115 cam
Long tube headers
3.33 gears (stock)
I'm running it as speed density - I do not have a MAF sensor. I'm also running it in open loop - I do not have front O2 sensors.
My best 1/4 mile time was 13.233 seconds at 104.81 MPH
60' time of 2.016
Looking through other threads, people with similar mods on the LQ4 are running low 12 second 1/4 miles.. I'm wondering if my tune is the issue. I'm somewhat of a noobie tuner. I have good power until about 60mph it feels like it sort of tops out on power (doesn't continue to pull as hard)
My tuning process:
Disable DFCO, disable closed loop, disable fuel trim, set new PE ratio
Using wideband, measure error of VE table - correct VE table
Spark Tuning - I'm not very sure how to do this without a dyno, I was told to just bump up the high MAP values to around 22 degrees
Transmission - Increased shift rpm to 6,000, increased shift time, sightly increased shift pressure. I did something for the 3000 rpm stall (disable misfire, did some other changes that I saw on a forum - can't remember exactly).
Could anyone take a look at it and see if anything is obviously wrong? Thanks!
Mods:
Long tube headers
3.33 gears (stock)
60' time of 2.016
My tuning process:
Shifting point for a cammed engine - I tried to get it to 6,000 rpm. Should I be at about 6,200 rpm?
Thanks!
If you look at your spark tables .72 and .76 air mass from 5600-6800 is less then the surrounding areas and those 2 rows are off compared to there surrounding areas.
Take a look at the attached tune file with some changes that I would suggest. Your VE table was very choppy. You should always work on smoothing the VE table as you work down the fuel trims. I threw in a timing table that should help make a lot more power. Your IAT timing table was pulling a ton of advance when the intake air got anywhere near 100° or hotter. Where is your air filter pulling from?
Hope this helps a little.
Clyde
Clyde
