Tuning for bracket racing
Thanks
Obviously your tune didn't change between runs, so it's exterior variables that are causing the change.
They are very consistant
* Any positive LTFT will be carried into PE mode at wide open throttle. This can cause inconsistency with your AFR. Be sure you tune for all negative LTFT.
* Delete any torque management and traction control
We have been doing the same with very good results. Had some cars get protested several times because they are so consistent. They were running foot brake, no electronics class and get accused of having something hidden in the car. We only handled the tuning, the driver is just very good and is very good at doing his routine the same every pass.
Thanks
