Running rough under load/ spark plug darkened
Old May 13, 2016 | 01:39 PM
2xLS1's Avatar
Just because some people are dumb asses and don't know how to properly use anti seize is no reason to say not to use it. I would do a leak down test on that cylinder, There could be a broken ring land below the piston top. I just keep going back to a mechanical problem because #7 is usually one of the first holes to break pistons with FI. You need to data log it when it is running bad. (choppy) and post the log file.
