Flooded car woes
I have drained all fluids. Filled the motor with transmission fluid. Changed out the T56 fluid and the rear end.
Now that I have dried and cleaned, and cleaned, and cleaned, I'm not sure what I need to do next. I have no codes. But I also don't have any engine bay power. I just don't know where to start. Is the ecm shot? All fuses are good. I don't even have a horn.
I'm aware this will be a pain to salvage. My father gave me the car in a trade and I would like to keep it. Sad part about it, the car looks great! No physical damage.
I'd start taking apart both fuse boxes to dry and clean them. Pull all fuses/relays, clean or replace them, clean all contacts with electronic circuit cleaner.
After that remove and disassemble BCM and PCM to check for damage, dry and clean including the harness pins.
Next, clean all grounds. You need to search the web for the location, there are several ground points and you need to clean all of them.
Install everything back and do a test, you should have at least basic power.
The car can be salvaged, but be aware that it will be a PITA for a while and you need to clean every connector and terminal. They will corrode sooner or later and start causing problems months after the flood.
