tuning issues LQ4
lq4,ported 243 heads,228r 114 cam,fast LSXR intake and BBK 92 mm dbc TB with 411 PCM. Vintage Air AC
I have been to two tuners chasing stalling issues over the last two years and after every visit some things a better and some are worse.
At this point we are chasing a stall at idle or coming to a stop with AC on. RPM pulls down @ 125 rpm when compressor engages. Some times it functions flawlessly and other times it stalls. I have a PSI harness with a 12v input to ECM when the ac clutch engages. Both tuners are freaked out that they have no tuning control via ECM (both HP tuners and EFI live).I know on a Snap on scanner I can see AC request turn on and off with AC. Any body have ideas on this? is this totally normal? I read online that people run VA with not AC signal wire with no issues. My car has been a finicky PIA idle wise since the swap was completed.
Also, maybe you should increase timing in the idle underspeed section so that when it drops below idle it starts adding additional timing to prevent it from stalling?
The A/C wire supplied (depending on where it goes) will only kick on the fan when +12V applied.
Its just a vacuum leak. You can run a brake booster sized vacuum line into the car, and uncap it just before you turn on the A/C compressor for the same RPM raising effect. Likewise, you can steal any Idle control valve from any vehicle with a built in 12+ or G- activated "air leak A/C kickup valve" and weld/bolt that into your intake tube and use it with a switch as well. Or a custom output from the computer.
Lots of options for adding some air during idle, from manual to electric.
