Alternator dropping voltage at WOT only?
I'd love to not have to put a new alternator in the car every time I go racing
Is there decent airflow to the unit ?
When I had issues some years ago, old 01 Camaro unit that worked for years eventually packed in. I had it repaired locally and again it served for another few years.
However this time when I got it repaired...it would stop charging at 6500rpm.
I bought a cheap alternator off ebay and it did the same bloody thing.
I then bought a 170A unit off these guys, along with a slightly larger pulley and it's been fine since
https://alternatorparts.com/ad230-ad...ternators.html
I did buy new regulators for the old alternators as spares...but never did try them again and I hope I never need to. Because again it would be a gamble as to whether they would work or not, and nowhere local would ever have the means to spin the alternator up to working speeds to test !
It could be a RPM Problem ?
Let us all here know.
I manufacture many "ALT" and can inspect one for damage.
Lance
The issues is alternator RPM, pure and simple. They typically stop charging around 18k RPM. You may get lucky with a nice new factory alternator over a cheapie reman, but they all do it. Buying a super BA alternator or slowing them down is the only way to fight this I'm aware of. Take your crank diameter divide by alt pulley diameter and multiply it times your max RPM. I have a 3.10" pulley. 7.5/3.10=2.4x7200= 17,419 rpm. I should be good. Haven't tested it yet, will report back.
I have that issue on a car I tune. Turbo car.
It however has a 25% UD Summit balancer. I haven’t done the math.
He finally bought a fancy Powermaster truck alt. Same issue.
Engine is now in a different vehicle, so much simpler wiring to deal with. I’m hoping it was the car!
If they all did it, there would be far far more people complaining about it
And doesnt everyone datalog ? They should. Although on a road car...if it was at night, the drop in voltage should be very obvious on dash lights and the headlights.
Sure with the factory diameter pulleys 7.5 and 2.25... You're looking at 20000 rpm at 6k. I'm not sure if the factory alt pulley is really 2.25... but anything around 6k plus is pushing it. My bone stock 2005 GMC truck does it at well. 109k on factory orig alt.
Here is a decent article on the subject... basically stating 18k is the limit for most.
https://www.hotrod.com/articles/0206...ur-alternator/
After I had the unit repaired one time..it started dropping out at around 6k. I too at the time read some BS articles about the brushes so I took the unit apart and added stronger springs to the brushes. Didnt make a bit of difference. Electric motors can spin much higher with brushes....so I do not believe they are the issue here.
Get that test rig sorted !! lol
voltage isnt critical to engine operation/safety at idle....it is at 6k and beyond.
But even at idle...it's not like the alternator isnt spinning like **** in either case.
Just get a good alternator, and it isnt an issue though. Or if really stuck, underdrive crank pulley and/or larger alt pulley if you were turning some very high engine rpm's and sustaining them
