Alternator dropping voltage at WOT only?
My experience wasn't much better. Installed the 3" pulley. (which is really 2.95" going by the area the belt rides on) It had a label on it stating it was regulated to 14.8. I assumed it meant it would charge at 14.8 if needed. It charges at 14.1 for idle and cruise. I did see 14.2 at one point. The old alt would charge at 14.6+ cruising and at idle with the same pulley. On low boost I made 5 pulls and voltage held at 13.1. Not the greatest but I guess it's working ok. I turned the boost up and it leaned out again. Voltage dropped to the 11's. So maybe it is belt slip. I ordered the billet ICT manual tensioner to try. But even when not slipping the power master didn't hold a 14+ to red line, which is a bummer. I also don't have the goofy monster amp draw from my Ford Taurus fan anymore. SO the draw on the system should be very little. I noticed a .4 voltage drop from the back of the alt stud to the battery term in the trunk. So I'll add another "0 gauge" wire form the alt to the BAT. IDK what else to do. Hope you have better luck!
I noticed black dust around the alt pulley, I bought a shorter belt. But I don’t have the volt drop with this car.
If you had a spare 0-5v analog input, it would be interesting to build a simple 3:1 resistor voltage divider and see what really happens right at the alt stud.
I haven't gotten to fiddle fiddle with my buddies truck that has this issue.
The issues is alternator RPM, pure and simple. They typically stop charging around 18k RPM. You may get lucky with a nice new factory alternator over a cheapie reman, but they all do it. Buying a super BA alternator or slowing them down is the only way to fight this I'm aware of. Take your crank diameter divide by alt pulley diameter and multiply it times your max RPM. I have a 3.10" pulley. 7.5/3.10=2.4x7200= 17,419 rpm. I should be good. Haven't tested it yet, will report back.
After the first pass it was only charging 13.3-13.5v. And it completely quit charging at 4800rpms and up.
So I called Mechman and got to talking to them about the issue. These guys build bad *** alternators. Yesterday It a 250amp Mechman alternator arrived at my door and I threw it in my car. They claimed it could be spun 25,000rpms safely. Has a slightly larger pulley on it and Charges 180amps @ idle 😳
This thing is a beast. Since the battery is in the back they wanted a 2awg charge wire ran and and a 2awg ground run to the case of the alternator. If the battery was up front, 4awg would probably handle the amps.
Plan on going to the track this Saturday so I will let you know how it works!
Just add a little boost to make up for the 25hp alternator draw 😉
I have 4awg welding cable ran from the alt back to the battery and they want it bigger 😳. I really don’t wanna re wire a brand new car either.
I suppose this would be true. I’m not a alternator guy (in fact I don’t know a damn thing about them lol). But if your doing a blast down the track with 60amps worth of fans running.. two big fuel pumps, lights (night race), etc etc etc... this alt will meet all that demand with headroom.
No reason at all to have fans running over say 30mph ( unless rad is in the rear of the car or something )
On load, during racing, I'd be surprised if most cars would actually be pulling more than 50-60A, unless it had some really insane fuel system and pumps.
Of course, plenty of CT options to log current too.
A Walbro 450 will pull over 20amps by itself at 4bar+ fuel pressure. So there’s 40amps just in the 2 fuel pumps. 40amps with fans if on high. So 80amps Then there’s the trans cooler fan, engine, and body stuff.
I think the kg3 (or whatever) truck alternator is way more than enough. It’s just those rpms. I didn’t wanna buy a $200 alt to chunk it again when I sleep on the shift or bounce the limiter coming out the burn out box. They said this the cheapest one we got (for the high rpms) but guarantee it’ll solve my my issues. So here I am lol
I didnt record it at the time though, but I think they were only around 15-16A each at just under 4 bar.
Something I keep meaning to test again.
Here is the Log:
Well it worked flawlessly... till it didn’t. Went up in smoke. I’ll update you guys after I talk to them Monday
ill see what they do. They have a pretty solid reputation. There’s always the douchebag move and do a charge back. I’ll give them a chance to figure it out though.
put the factory alternator back on and dealt with 13.3v and it stopping charging at 4800 for the day
