HP Tuners Question - 2.24
As of today I can no longer switch units to Imperial in JUST one section in the editor.
The "Base Running Airflow" chart is stuck on "g/sec" while ALL else is showing Imperial. (When selecting imperial)
I can switch back and forth from Imperial to Metric just fine, but the BRAF sticks in g/sec.
Im still on 2.24.1021
Thank You for your time.
Ok i tried but ls1tech wont let the file is too big.. so if you want the hp tuners 2.24.1172.msi file skype me at the404man_Osborne
You can run 3.2 and 2.24.1172 together
and here is 2.24.1172 and do the following to allow them both to be installed
Ok to get 2.24 and 3.2 running on the same computer (and have both be fully functional), you need to do this:
1. Ok now If 3.2 is already installed, un-install it (save any files you need first)
2. Install 2.24 to the *default* installation directory
3. After its installed, manually rename the installation directory from "\Program Files\HP Tuners" to "\Program Files\HP Tuners 2.24"
4. Re-install 3.2 to the *default* installation directory.
At this point, both 2.24 and 3.2 will be installed. However, the startup shortcuts will start 3.2. You have to manually create new shortcuts to the 2.24 binaries (basically, right click on the Scanner and Editor .exe files in "\Program Files\HPTuners 2.24\VCM Suite" and click "Create Shortcut".
Oh and don't save changes to files you open with 3.2 if you want to use them again in 2.24
happy getting used to 3.2 and while still enjoying 2.24
peace
peace
If he's like me, he doesn't like incremental change if what he's using now works perfectly. I will continue to use my current tuning setup in my car, which includes using 2.24, until I'm no longer running a stock GM computer.
Once you take a 2.24 .hpt file and save changes with 3.0+ you can no longer use it in 2.24
