knock sensor . only getting .8 volts from pcm
i got the 327 and 332 codes. i replace the sensor and harness. but the code came back. i get 100 ohms on the sensor . but i only get .8 volts from the pcm. i check to see if the wires were good from the pcm to the connect and all good. could the pcm be bad.
