2000 Camaro LS1 Stalling and Rough Idle
Mods:
-GM hot cam kit
-long tube headers
-full exhaust
-tuned by frost
I also deleted the air box and rear o2 (tune to accommodate deletions).
Symptoms:
-rough idle
-occasionally stalls if medium throttle to brake (braking for a stop light)
What I've done:
-cleaned iac
-cleaned maf
-idle is set to 750 rpm
-fresh gas (sat for a few months while I rebuilt motor)
-no check engine light (nothing pending)
Yes stock converter. Not to concerned about the choppy idle. I wanted something one step above stock. I thought the stock converter was ok, apparently I think I was wrong
. I have not contacted Steve to get an update because I have been trying to make sure it wasn't a bad sensor or something wrong mechanically. I think I'll get a new torque converter. I'm thinking about the Yank ss3600. I've seen a lot of people say they are good for a DD. Start there and see what happens.
My cam is on a 115LSA and I currently am running my stock converter and had the same issues until I upped my rpm's at idle and adjusted timing. You may need to idle around 900rpm due to the 112 LSA on that cam. With upping the idle you are going to feel like you are pushing through the brakes (feel like a cruise control effect). Nothing you can really do about it other than lower the idle. I would even suggest upping your idle to around 950 so you aren't fighting the stalling issue, then you can look at your VE tables and EQ tables and get it tuned correctly. Once it's tuned correctly then you can lower your idle.
Basically whats happening is due to the LSA and cam duration at 750 rpms your car isn't creating enough vacuum and causing your car to stall... It would be much like creating a vacuum leak in your system and expecting your car to run fine. Hopefully that simple explanation makes more sense..?
Whats your commanded AFR, I assume 14.67?
What's your EQ table look like? Engine>Fuel>Open and Closed Loop>Open Loop>EQ ratio
I assume you do not have a wideband?
Maybe you are becoming more active here because its getting dark in Alaska?
