Logging control module voltage
ive seen mine as low as 12.5v while racing.
Normal seems to be 13.2 or so.
With the batt in the trunk, and the long alternator charge wire, I do have more voltage drop than I'd like to see. So I'm fixing that now.
So no, nothing to be concerned about.
. Is this a 411 PCM? If yes, Blue Pin 19 is ignition feed and Pin 20 is battery feed.
Also compare the voltage at the alternator and at the battery.
I had to run a 4 Gauge wire from the Alternator to get everything over 14 Volts.
It stated, it probably isn't an issue, but I like all the wiring and voltage to be correct.
When I check the voltage on the fuses with the engine running I get:
battery - 13.3V
ignition - 12.3V
injectors - 12.3V
fuel pump - 12.3V
battery - 13.3V
ignition - 12.3V
injectors - 12.3V
fuel pump - 12.3V
battery - 14.5V
ignition - 10.6V
injectors - 10.6V
fuel pump - 10.6V
Its truly odd there is such a drop since im getting my switched 12V right from the ign relay in the rx8 fuse block. Did you ever figure out what caused your difference in voltage?
