Cold Start issues 2000 Camaro
Old Jan 18, 2017 | 01:36 PM
RonSSNova's Avatar
Default Cold Start issues 2000 Camaro
I installed a new engine in this car here at the shop.
I have no experience with it prior, so I don't know if it started cold prior or not.
I have not altered the tune that would affect cold start as far as I know. I've just done part throttle and wot tuning.
What I see is that the IAC position is at 0 when I try to start it cold.
IAC desired is at 0 as well.
The cranking pulse goes rich as expected the first time I try to start it. Sometimes it starts, but really struggles.
If I shut it off and re-crank it, the pulse width goes to 20-30ms and stays there.
It's flooding itself.
It does seem to be following the cranking pulse fuel table, commanding approx. 8:1 AFR.
TB is a BBK 90mm.
Kind of lost! It will start if I floor the pedal......and restarts fine when warmed up.
Injectors btw are unknown short fat things. Other than data from the original tune it came in with, the injector data is all stock except for the flow rate. I don't even think that was correct, but it ran. It's a pretty much hacked tune......I'm trying to correct all that.
So question:
Shouldn't the IAC go to 310 park position?
I've disconnected it, cycled the key to reset it, but it seems to want to stay at 0.
Once it's running, it begins to open and ends up at 310 then works it's way down as it warms up as expected.
Ideas?
Ron
Old Jan 18, 2017 | 01:49 PM
JakeFusion's Avatar
Super Hulk Smash
Yeah, if the IAC Reset Position is set to 310, that should be the start position. If not, then I'm not sure what would cause it to open up all the way. But if it's open all the way, you'll have to essentially flood the engine for it to ignite (as you're seeing). Have you tried a different IAC? If it's working as expected after start up, it might be fine. Weird.
A possible bandaid would be to set the 400 column at 100-105kPa in the VE table like 10-15% richer. It always seems to hit there on startup and if I lean out those cells, it does get harder to start. So that's a hack answer.
I'd also write full to make sure the tune isn't corrupted in some manner.
Old Jan 18, 2017 | 01:52 PM
psiconversion's Avatar
LS1Tech Sponsor
Sounds like your coolant temp. sensor is open, reading -38*. Check the reading on your scan tool.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jan 18, 2017 | 02:56 PM
JakeFusion's Avatar
Super Hulk Smash
That may be the answer right there.
Old Jan 18, 2017 | 03:01 PM
LS1Tech Sponsor
Let me know what you find. Thanks.
__________________
Ebay Store
Old Jan 18, 2017 | 03:20 PM
RonSSNova's Avatar
Thanks guys.
Since I've come to work for this shop, I tune Mopars......don't hit me! Ha.
I don't have my log files here for the GM cars I've tuned, including my Nova so I'll have to look see what cold starts look like on those.
I did check the IAT value and it says 50F. Same with coolant temp.
I'll bring a known good IAC in tomorrow and try that.
I will also do a write entire, it never hurts.
Thanks
Old Jan 18, 2017 | 05:08 PM
2xLS1's Avatar
It can.
Old Jan 18, 2017 | 09:54 PM
RonSSNova's Avatar
Originally Posted by 2xLS1
It can.
it didnt
Old Jan 18, 2017 | 09:58 PM
2xLS1's Avatar
Bet it didn't fix the problem either.
Old Jan 18, 2017 | 11:26 PM
RonSSNova's Avatar
Ha. No it didn't. :-)
It's a bit difficult as you only get a few tries at cold start.
Looking at cold start logs for my Nova, IAC is at 200 when I start it. Same temp conditions.
So either I have a goof in this tune, or the IAC is sticky.
Old Jan 19, 2017 | 06:04 PM
RonSSNova's Avatar
Batt had died. And as I Remember, these things tend to lose their idle brains when the batt is disconnected.
it also appears that this aftermarket FB lacks enough IAC area as it wants more air at cold idle than 310 counts can deliver at the cold idle speed I selected.
ill fudge it around a bit with the throttle screw.
