Need Good VE Map for LS1 2002 camaro
Old Jan 27, 2017 | 08:19 PM
ls1_lover's Avatar
Default Need Good VE Map for LS1 2002 camaro
I have hptuners. can someone share a good VE map with me. I want to work on the Long Trims but need a good VE map to start with.. thanks.
Old Jan 27, 2017 | 09:23 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Not to be an ***, but the HPtuners (the place you bought tuning software) tune repository has the largest collection of good VE maps you will ever find for your software. They also have a forum with over a decade of good info on what to do with these tune files. Get started there, and then come back here with more detailed questions.
Old Jan 28, 2017 | 10:06 AM
jaydubb's Avatar
Why not try to tune your VE map? Do you know how to log and make adjustments? I wouldnt start out with anyones VE map. Rarely are they close to what the car needs.
Old Jan 28, 2017 | 01:42 PM
JakeFusion's Avatar
Super Hulk Smash
HPT comes with samples... one of them is a 2002 Camaro... just copy that one in if you need a stock map to start with.
Old Jan 29, 2017 | 11:08 PM
subeone's Avatar
Keyboard cat will generate one for you, let me know. Catnip works as payment
Old Jan 30, 2017 | 08:45 PM
ScottyBG's Avatar
Why not start with what is in your car, you said it ran well in an other thread? It is probably a good starting point, you could bump it all up by like 5 or 10% if your concerned about going lean while tuning. Just select the whole table and put in like 1.05 in the box up top and hit the multiply button. But that probably isn't necessary.
Old Jan 31, 2017 | 02:22 PM
jimmyblue's Avatar
Moderator
Nowhere is stated the motor build particulars
(from TB to exhaust tips). "Good" means that
the table matches the reality.
On the HPTuners repository you can look at the
comments attending the tune files, and check out
ones that look reasonably similar.
LTFT tuning does not want you to start with the
VE table. It wants you to start with externalities
like sensor health and fuel pressure. O2 sensor
false trimming, MAF crustiness, IAT heat soak all
are likelier actors than a stock car's tune params
being suddenly wrong. Fuel filter and catalytic
converter obstructions / clogging are also "health
issues" unrelated to "PCM psychology". Fix the
latter first and you'll be fouling the brain by
"fixing what ain't broke" while ignoring (or not
knowing) what actually is.
