commanding 13.21 instead of 14.68? Need some help please
Thanks for any help.
The ratio should only change if you add fuel to the tank, it should stay constant throughout driving. I'm not thinking you really have a problem here, just the numbers are not what you are hoping to see. Maybe if your ethanol sensor is reading off a little you compensate for it by commanding 1.15 under power enrichment?
Jason Haines
Product & Service Solutions LLC
www.proservsolutions.com
https://www.facebook.com/proserv/
I dont run E85 and I would prefer to not be trying to hit a moving target while tuning.
Most of the newer non-flexfuel GM vehicles have the table flat lined at 14.1:1 instead of 14.68.
Jason Haines
Jason Haines
- Disable virtual FF and put a fixed flat-lined AFR level in the target AFR table (then our AFR comments in our prior post become important)
- Add a real flex fuel sensor
Jason Haines
