High IAC After New Injectors
I changed to a Flex Fuel OS which warranted new larger injectors. Now I'm having a VERY hard time with cold start and IACs. At first I was having AFR issues but that's been taken care of. When I get it to run it idles around 14.5 AFR hot (185*) at 65ish KPA. Now I've noticed that my IACs stay above 115 hot idle where-as before the injector install they were at 60-65. When I try to open the throttle body blade to lower the counts I surpass the TPS voltage threshold and the RPMS shoot up. As of now the TPS volts sit at .57 with the TPS % at .4 with 115+ IACs. For some reason with the car off but key on the TPS % is zero and the voltage reads .55, it then jumps to .4% and .57 volts with the car running. I will, if I have to, drill the blade but I want that to be my last resort. I'm trying to tackle one problem at a time so any help OR suggestions is greatly appreciated.
Moderator
Received 1,852 Likes
Ok unless you didn't change injector data, basically it sounds like its working right.
When you turn set screw to a higher voltage, the TPS sees throttle. 0.4% is the lowest it will typically see.
Set your bolts to .59. Then unplug TPS. Key on engine off for a minute. Key off and plug in sensor. That should zero your TPS at 0.59 volts
