LS1 run issue; i need help!
if problem persists then read codes again
i'm beginning to think that there is something in the code that is looking for a signal from a sensor that's not there and it shuts off the fuel pump. but i don't know because i don't know squat about programming the ECM.
this will reset the ECM
Not unusual to find the Vette reg/filter has some psi variation.
They are not rated at 65psi in that filter/reg.
We use WIX units, and find "most" are at 4 bar.
