got a light on and temp gauge is dead *help*
That light is the low coolant level light which is pretty common on these cars because the sensor gets gummed up and doesn't read correctly, but it's definitely a good idea to make sure your coolant level isn't actually low.
It's strange your temp gauge stopped working shortly after that. It could be a coincidence or you could be having cluster problems.
