01 4.8 swap help stumble on accel
01 4.8 out a silverado swapped into an 87 suburban w/ t400
pcm and harness from the same engine
Stock other than shorty headers
Stock 01 truck fuel pump in the 87 tank
Only issue that I am currently trying to workout other than the tune is the vss. Of course you guys may see a lot more.
Stumbles on acceleration in low rpm ranges.
Will cut out intermittently cruising 30-40 mph. At highway speeds it runs pretty good.
Check out the tune and the log and let me know what you think.
Thanks,
Chris
Thanks,
Chris
Throttle cable is a one off piece that is still under construction. It isnt quite right yet. Wanted to get it lined out before I worried about that stuff. Wanted to get it running good before I worried about WOT.
Thanks for looking at it.
Took that out for a quick spin. Driveability is still the same. Still has the stumble at lower rpms at 20-40% tps.
Bank 1 is consistently high on the ltfts. Not sure why, no codes and no misfires.
Thinking it could be the shitty exhaust work pulling air in right above the 02 sensor.
Included the log file.
your fuel trims are all over the place. Either your pulling in air somewhere before the 02 sensor, or you have them switched side to side.
I would get that figured out before you do anything else.
