Injector plug key on volts
What happens if you unplug your relay, does your 5 volts go away?
Also make sure you are not overloading your relay with too much current draw, they can overheat and stick.
when the injector is off, its ground pin should pull up to 12V, you should measure this with injector plugged into harness, and key on (engine off).
