Speed density with or without o2s?
Also if you are running closed loop with a front mount turbo where did you put your o2s for good readings without burning them up?
The UEGO is effected by EMAP with a higher AFR reported as pressure is increased.
Th EGO, four wire, is effected by temperature OVER 1500F with a higher AFR reported with temperature increase.
The Alpha-N mode is commonly used for SC engines when MAP-Comp is specified AND Mixed to allow for the correct PW.
I run Closed Loop as much as possible.
Lance
So, cliff for the narrowband, use or dont use, put anywhere you want, when you are making power it kicks into open loop anyways so any interference due to temp or pressure isn't a concern.
Wideband on the other hand, you want/need, in any performance car needs this or can use a wideband. It should be put away from the high temperature/pressure source i.e. downstream of the turbine a couple feet if possible. Some widebands have an analog output also (like the ever popular AEM I always use) so it will do a "narrowband simulation" for the oem computer to think you have the narrowband still. In many sensors you can program the narrowband output, I use for example: (15.2:1 @ 0.005v and 0.995v @ 14.85:1) So it holds mean lean as if I were in open loop programmed lean (except now the computer can keep correcting it lean)
