SD Tune AFR stability at WOT?
The turbo truck I had before, which was tuned by a shop - had a 11.1 AFR at WOT and it was dead set on 11.1, didn't move around at all on my wideband gauge. I believe that tune was MAF though
Is it normal for an SD tune to not be 100% on the money as far as VE table is concerned?
Sorry to hijack this but there are a few of you on here I follow and wow I've been away too long lol.
OP if you're AFR is moving around like that then either the boost or the fuel pressure is likely moving around too. Like trying to hit a moving Target. Is your fuel pressure regulator boost referenced?
