Idle too high at start up
Old Sep 20, 2017 | 07:31 AM
Larry's Avatar
Default Idle too high at start up
I've tried these setting but my idle still jumps to just over 1000 rpm at start up. How would I reduce start up idle to match the tables?
2017 C7 Z06 Corvette
File Type: hpt
Old Sep 25, 2017 | 08:00 AM
gagliano7's Avatar
I can't look at your file. Not sure why since i am up to date on the software.
Old Sep 25, 2017 | 10:12 AM
Larry's Avatar
My file was read with 3.7 Beta is most likely why you can't open it.
Old Sep 30, 2017 | 02:47 PM
JakeFusion's Avatar
Super Hulk Smash
Friction Airflow Initial in the idle airflow>startup area will cause a flare. I haven't updated to 3.7 yet, so I can't read the 2017 file. But I would wager there is a similar table there that dampens the airflow on startup.
You may also need to reduce your cranking timing a bit if you're getting the flare.
Old Sep 30, 2017 | 06:58 PM
Larry's Avatar
Here's my file downloaded with 3.6.
I've tried making some modification to cranking advance to no avail. Probably didn't enter the correct values??? Not sure where the other tables you are referring.
File Type: hpt
Old Sep 30, 2017 | 07:47 PM
JakeFusion's Avatar
Super Hulk Smash
Under General>Cranking Airflow and Torque>Base Airflow, it has airflow by ECT and duration. You might try to reduce those numbers some in the 1 sec and under times by 10% at a time until you don't get that flare.
I'd start there.
Old Oct 1, 2017 | 01:03 PM
Larry's Avatar
I'd start there.
Tried lowering some but will have to work on it more. Thanks for the info!
Old Oct 1, 2017 | 06:24 PM
JakeFusion's Avatar
Super Hulk Smash
Did it help at all? Typically, when a car flares like that it's because of too much startup airflow or timing is too high. That's the one table in the 17 C7Z tables that seemed like it would be helpful.
But being that it's startup, it might take a couple of days to get it, especially if it's at cold start.
Old Oct 1, 2017 | 06:33 PM
Larry's Avatar
I really can't tell it helped. Although I'm going by sound and feel so it could have a little. Not what I would like yet.
Here's the table I downloaded. Not just the 1 second and down but all the way across.
