Vats wont disable
2002 camaro
Bought a 2004 GMC and it randomly began to not start every once in a while. There was no consistency. Drove for about a week or two after buying it when it refused to start the first time. I thought that VATS was the problem so I unlocked the PCM and and disabled the VATS. I thought I had solved the problem. Later on the truck refused to start again so the VATS removal didn't help it.......
I then learned about the PASSKEY bullshit so I researched that a good deal and ended up determining the resistance the passkey system was looking for by measuring with a meter. I soldered in resistors to replicate the expected resistance the PASSKEY system was expecting. I was sure this would fix it..... It didn't.......
What I finally ended up doing is putting a momentary switch in the dash that is tied to the "Starter Enable Relay". I never was able to figure out why this no start issue happens from time to time, but whenever it does, I just hit the momentary switch and it starts right up that way. It bypasses all the onboard bullshit, BCM, VATS, PASSKEY...... All those systems have to play nice together in order for the starter enable relay to finally be enabled to start the vehicle......
Mine has been trouble-free starting for a month, but since draining the battery down the other day, diagnosing a non-related issue, it has failed to start twice, maybe 3 times...luckily, while still in the garage.
The SECURITY light would come on very intermittently, while driving, but since recharging the battery, it has come on, at KEY ON, like said, maybe 3 times, and stayed ON, which wouldn't let the car start.
Car is a 2000 Trans Am with 2002 Silverado, 3 bar S/D OS...VATS disabled via my HPTuners. and not sure what else to do.
But if the car has the "Starter Enable Relay" you can tie in to that like I mentioned above and bypass it every time.
There's the bypass switch I installed.
Here is the relay I tied into to bypass all the onboard bullshit. I tried for weeks to fix it the "right way". I decided this was the better fix... All the onboard bullshit GM put in is more effective at keeping you from driving than someone from stealing it.
It's been a few months since I went through that headache so I can't remember the specifics but basically the switch I added will close the relay contacts thereby sending voltage to the starter solenoid.... It's a switched ground IIRC... so one of the wires from my bypass switch goes to one of the relay pins that ordinarily would get a ground if all the onboard bullshit is working correctly, and the other wire from my bypass switch is just grounded out to the frame... So when you hit the switch the relay has no choice but to close the contacts and send voltage to the starter.....
