Holley global repository
i know now before it was because they were very hard to share because they were “folders”
but v4 software turned all tunes to one “file” now so it should be easier....
thoughts?
thoughts?
Now that I think about this more. There is no longer a folder that has a file for each ICF when the V4 saves and this is a good thing. It allows you to email the tune without compressing it. You can still save each ICF if you want from the program, but your tune should be 1 file now. This also shouldn't over write your old files, so you can still open an old one and check it all after importing it if things went wrong some how. You can also still flash back to V3 or V2 firmware if you don't understand the new features or layouts.
I agree that every tune is 100% custom with holley due to all the I/Os, but I do think there is some benefit to be had in opening other peoples tunes in order to learn from them.
good job on Holley's part though for trying I guess
Obviously that wasn't the only change in v4 but it's a fact it made it easier to share....
Their bas cal's are OK but I don't like a lot of the timing maps they have.
Enable CL immediately. Learn won't start till your fuel modifiers are 100%. But unless it's WAAY off CL will at least let it idle, given the TB is open enough.
You can look at their base cals if you need help with the VE table. If you have an honest idea of how much power the engine makes its pretty simple to set the VE table for WOT, actually it's lbs/hr and it takes a very little fuel in the idle area.
Forgot to come back in here in post this. Says in v4 it's now easy to email files. Sounds like they knew it was difficult and changed it.
I've done computer trouble shooting over the phone and I'm still amazed that people can't follow simple step by step instructions in real time. With the Holley system it to easy for them to miss one little step in the basic setup and that basically turns into a no start issue. What helped me is that I'm good with computers and the electrical/mechanical aspect of it and have a decent understanding of tuning, If you're lacking in one of those area's it can be frustrating figuring it all out the first time. So in the way that it makes it easier to send a file to be diagnosed is helpful to those that had trouble figuring out how to send it but as far as actually sharing a file I don't see the need so much.
In some ways having the complete tune in one file could be dangerous/expensive/harmful. If I share my complete tune in one file and someone downloads it and sends it to the ECU without picking it apart first it could easily cost them something as simple as a 02 Sensor or worse...a complete engine.
As far as sharing tunes, Unless you happen to be running the exact same combination most tunes are almost useless. Just using a different injector or different map sensor would make a copy and paste of fuel table (or any table)a bad idea and looking at them is of no help because the numbers may or may not be close to what you need.
There are just to many variables/possible combinations to make it really feasible.
One of the reasons it works for HPTuners is that most of the time you're dealing with slightly modified factory tunes that are being used on nearly identical engines so you see tunes that are for LS3 with X cam and long tubes or LS1 with x injectors and x cam yet they all use the same oil pressure sensor/temp sensor/map sensor/same cam and crank sesnor, Then they have separate controllers for boost, water/meth injection and so on....That's not usually the case with a Holley setup, It controls everything and can use a number different sensor combinations.
Agreed. The Holley instructions IMO are pretty damn good. A lot of people get impatient and hurry with the install and forget to to all the preliminary checks.
They also periodically update their instructions which helps. For example the old instructions for the dual sync dist. were damn confusing. Tom re wrote them and it's pretty difficult to mess it up now if not impossible.
Prior to that all my first starts were smooth as butter....Wire it...Plug in the ecu.... Set it up...turn the key and boom running.
Replaced the regulator and all was good. If I would have done what I should have, it would have saved me a lot of time.
