Inexpensive Opensource Flashing(Read is 100% working)
Old Nov 7, 2018 | 11:10 AM
  #281
Scott68B's Avatar
Originally Posted by G Atsma
One question so I don't hijack the thread: Which tranny did you use behind the LS4? Never seen one used in a north-south (rear drive) configuration.
I used a Ford Mustang V8 T5 behind a 94/95 Chevy S-10 2.2l bellhousing which has the Ford trans bolt pattern.
Old Nov 7, 2018 | 01:26 PM
  #282
OK, thank you! Which leads me to wonder if an LS4 would bolt to a 2.2 Cobalt transaxle in a Goblin kitcar….
Old Nov 8, 2018 | 01:33 AM
  #283
Doctor0's Avatar
Thank you for your responses. This was done in the car. I put an LS4 into my MGB so I'm using a stand alone harness. I'm using a 0411 which I believe I got out of an 01 Chevy Blazer 4.3 V6. It isn't factory, I had it flashed by a well known tuner in my area and it was based on a manual transmission 12202088 OS. It runs really well but I've had some weirdness with my OBDII port that I will need to troubleshoot. I'm going to a bench setup in the next few weeks, i think I have almost everything I need including a spare 0411. Just missing an OBDII port for it.
Thanks again for your help.
I have an extra obd2 port connector. Send me a PM with your address and it's yours.
Old Nov 10, 2018 | 09:03 PM
  #284
jamesr's Avatar
Originally Posted by PeteS160
The odds of getting a genuine VxDiag on Ebay is virtually non-existent right now unless you know something I don't. As we get closer to a beta release I will likely try and track down a seller either on Ebay or Amazon that we can work with to make sure they have the 100% real deal so we can have confidence when we point someone at a device that they will be getting something we know for a fact will work.
I have no issue buying cloned hardware out of my own pocket and testing it..... and I have been over the last 6 months or so......however unless your dealing with the actual manufacturer of the clone'd product there is no way of knowing if the next batch they get will be the same quality. I have sent back more devices that didn't work correctly than I have kept.......I've had to take a break since Paypal sent me a warning for excessive return claims near the end of last year and is the reason I turned to Amazon.
We are supporting a number of inexpensive devices that will likely be superior to most if not all poor quality knock off devices like the worldobd2.com Mdi or most Ebay VxDiag nano's.
I had issues using my vx nano but I guess that was the software bug. Any surefire way though to know if it's the real deal or a cloned one? Got it from amazon and so far everything has worked, including tis2000 flashing, so it's probably the real deal or at least really good clone?
Old Nov 13, 2018 | 12:03 AM
  #285
bumpin_z's Avatar
I received my Allpro cable over the weekend. It took installing some generic drivers but once I did that, it worked like a champ!
Old Nov 16, 2018 | 01:43 PM
  #286
Arcturis144's Avatar
Any word on an update for so those of us that have a vxdiag can try this out?
Old Dec 5, 2018 | 02:04 AM
  #287
PeteS160's Avatar
After three long nights of torment....The counsel of pcm gods have agreed that after many years of torment and being imprisoned it was time to begin the purge .......and a mighty hammer was called down from the heavens that would bring justice to the tuning world for anyone willing to spend at least $29.99 on a flash tool! ! ! !
While the hero is still young and in training.....the Hammer is quickly proving to be a worthy adversary in battle that should not to be taken lightly.
Spoiler!
Old Dec 5, 2018 | 02:39 AM
  #288
NSFW's Avatar
I'm pretty stoked about this too.
A couple weeks ago I erased the calibration from the PCM that I've been using for testing. I was trying to write new calibration but ran into some surprises, so that failed. Thanks to PeteS160 and our new kernel-dev teammate (not sure he wants his named shared or not?) my bench PCM is back to normal as of a few minutes ago.
We still have issues to work on, for example, after successfully updating my calibration, the app just started spewing error messages because it didn't recognize the "done" message from the kernel code. And this stuff isn't solid enough that I'd try it in a car just yet. But it's coming along.
Old Dec 5, 2018 | 02:43 AM
  #289
NSFW's Avatar
Arcturis, the fix for vxdiag and other J2534 tools is in the works. I can't promise a timeline but it shouldn't be long.
Old Dec 5, 2018 | 06:39 AM
  #290
TPIZ92's Avatar
Thumbs up
nice work Pete!
Old Dec 5, 2018 | 08:02 PM
  #291
dubsjw's Avatar
Hi all! My brother and dad are both into flashing ecu's and showed me this thread as I am a software engineer. I can say that I am intrigued. I write daily in C++ and Python and have experience with other languages as well. I own multiple raspberry pis and arduino and my brother has a pcm and can make the bench cable setup. How can I start to help with this? I'm sure I'll have to familiarize myself with the terminology, but I don't think that will take long.
Old Dec 5, 2018 | 08:27 PM
  #292
truckdoug's Avatar
a pcm, a bench harness, an allpro USB adapter, a copy of tuner pro and then the latest version of pcm hammer from pete or nsfw
Old Dec 5, 2018 | 09:05 PM
  #293
dubsjw's Avatar
Sounds great. I read through the thread and I think I have a decent understanding of what's going on. I'll gather all of that stuff, build the solution from source, and play around a bit. Thanks!
Old Dec 5, 2018 | 10:37 PM
  #294
NSFW's Avatar
Here's the code:
https://github.com/LegacyNsfw/PcmHacks
You'll need Visual Studio (the "Community" edition is free) and make sure you include C# when you install it.
There's also a little bit of plain-C code in there, but that's just experimental at this point. It can send messages over the OBD2 connection, but not reliably, and it can't read messages at all. But I like the idea of doing kernel development in C (with a little inline asm where necessary) so I'm tinkering with it. The installer for the cross-compiler is checked in as well, just for convenience.
The real kernel development is being done in 68332 assembly and isn't on github yet. It's probably going to stay closed-source for a while, so we don't end up with knockoff projects hitting the market until after we've got a head start in the popularity contest.
I'll PM you some contact information, stay tuned.
Old Dec 5, 2018 | 11:52 PM
  #295
PeteS160's Avatar
If you are interested in working with C++ the Arduino project that I started this thread with hasn't seen any love in quite some time. It's very capable of being integrated with the Pcm hammer or could be extended a bit more to run stand alone reading/writing to an SD card as well. You can shoot me a PM if that's something your interested in or you can coordinate with NSFW if you'd like to work in C#.
Either way we'd be glad to get you on board with what we are working on. In this case the more hands and eyes we have the faster and smoother things will go.
Old Dec 6, 2018 | 11:22 AM
  #296
I just got an allpro yesterday, reads flawlessly. am still willing to test with the j2534 when you have it ready.
Old Dec 6, 2018 | 01:22 PM
  #297
punisher454's Avatar
Did I see that youtube video correctly, you can now flash, or is it still just read?
Old Dec 6, 2018 | 02:20 PM
  #298
NSFW's Avatar
We have successfully flashed, yes. It's a really cool milestone.
I'm pretty sure the number of successful flashes is still much smaller than the number of failed flashes, though... We still have work ahead of us, to make it reliable enough to use in a car that anyone cares about.
Old Dec 6, 2018 | 05:16 PM
  #299
dubsjw's Avatar
I need to wait until I get over to my brother's place to test out the C# build and get my head wrapped around where this is at and then I might start messing around with the Arduino side of things. I'll let you know when I'm ready for that.
Old Dec 6, 2018 | 11:14 PM
  #300
joecar's Avatar
+1 very cool milestone
