Inexpensive Opensource Flashing(Read is 100% working)
Old Nov 19, 2019 | 01:49 AM
  #721
NSFW's Avatar
THANK YOU SO MUCH.
I just unbricked one of the P59s that I bricked months ago.
Old Nov 19, 2019 | 11:01 AM
  #722
Originally Posted by NSFW
THANK YOU SO MUCH.
I don't know... sounds like sorcery to me....
Just kidding! Man, that's gotta feel good!
Old Nov 19, 2019 | 05:15 PM
  #723
NSFW's Avatar
It does. I've been wanting to finish the P59 reflash stuff for months and now I can finally work on it again. Especially since I have some free time coming up next month.
Old Nov 22, 2019 | 08:59 PM
  #724
NSFW's Avatar
Since fixing that bricked P59 a few days ago, I figured out what went wrong in the failed flash, and have reflashed it several times without issues.
PeteS figured out why that flash failure bricked it, and I'm going to make a couple changes to prevent bricking in the case of random failures.
Tazzi has a couple of changes in mind that will make it more reliable with ScanTool interfaces.
When all of those changes are in, I'll put out a new release. Hopefully within a couple weeks.
The next release will include a data logger, but the data logger will probably suck. The next-next release, hopefully before January, should have a data logger that actually works reasonably well.
Old Nov 22, 2019 | 10:40 PM
  #725
Why not wait until the better data logger is ready? Then you don't have to worry.
Old Nov 22, 2019 | 10:54 PM
  #726
NSFW's Avatar
I just want to finish up the P59 stuff and get it out there. I know what to do, and I think it won't take long.
The data logger... It does work, but it occasionally pauses for too long between rows of data. I have some ideas for fixing that, and making it faster in general, but it might take a lot of trial and error to get it right, so I don't know how long that will take.
Basically if there are P59 people out there who want to reflash, I don't want to keep them waiting while I fumble around with getting the data logger to work better.
  #727
i420tom's Avatar
THANK YOU SO MUCH.
You are welcome! Glad I could finally contribute something tward these great projects
Old Nov 24, 2019 | 06:34 PM
  #728
NSFW's Avatar
I just put up a new release with support for writing to the calibration and parameter blocks on P59s:
EDIT: There was a bug. Use Release 8 instead: https://github.com/LegacyNsfw/PcmHac.../2019.11.25.01
Keep in mind that I don't actually have a vehicle with a P59, so I've only done bench testing with it. But I've reflashed the PCM on my workbench about a dozen times now.
Who wants to be the first volunteer to try it in a vehicle?
Keep a spare PCM handy just in case.
Old Nov 25, 2019 | 01:28 AM
  #729
Red Beard's Avatar
Hello I have a pixel XL on Android 10 and ls-droid says my version of Android is too old?
Old Nov 25, 2019 | 08:39 PM
  #730
i420tom's Avatar
tried read full in vehicle and had errors, full logs of p59 emailed to you. It is a custom 3bar operating system from HPT. Tried 2 different adapters, allpro and vcx nano,
had to disconnect battery to revive pcm each time
Edited to shorten message
Old Nov 25, 2019 | 10:40 PM
  #731
NSFW's Avatar
Originally Posted by i420tom
tried read full in vehicle and had errors, full logs of p59 emailed to you. It is a custom 3bar operating system from HPT. Tried 2 different adapters, allpro and vcx nano, same result error summary below
[08:25:23:655] No payload following read request.
[08:25:25:671] ReadMsgs OBDError: ERR_BUFFER_EMPTY
[08:25:25:671] No payload following read request.
[08:25:25:671] Something went wrong. Offset and length were out of bounds for the array or count is greater than the number of elements from index to the end of the source collection.
[08:25:25:686] System.ArgumentException: Offset and length were out of bounds for the array or count is greater than the number of elements from index to the end of the source collection.
at System.Buffer.BlockCopy(Array src, Int32 srcOffset, Array dst, Int32 dstOffset, Int32 count)
at PcmHacking.CKernelReader.<TryReadBlock>d__5.MoveNe xt()
--- End of stack trace from previous location where exception was thrown ---
I got your email, and I think I know what the problem is. I'll need to do some testing to confirm this theory but if I'm right, the issue you ran into will prevent anyone from reading a P59, so I'll probably have to put out a new release to fix that. Stay tuned....
Old Nov 25, 2019 | 11:00 PM
  #732
NSFW's Avatar
This is a little embarrassing, but the fix is...
1) del read-kernel.bin
2) copy write-kernel.bin read-kernel.bin
In other words, write-kernel.bin works for both reading and writing.
The P59 requires a small change in the kernel, and I only made that change in the write kernel, because I forgot that we had two kernels, Because the write kernel does work for both reading and writing.
I'll put out another release that just has a single "kernel.bin" to simplify things.
Old Nov 26, 2019 | 01:58 AM
  #733
NSFW's Avatar
Release 8 is up now: https://github.com/LegacyNsfw/PcmHac.../2019.11.25.01
Old Nov 26, 2019 | 02:09 AM
  #734
i420tom's Avatar
Did this with release 7 and read OK but bins created were 512kb and would not write(corrupt?)
Old Nov 26, 2019 | 02:36 AM
  #735
NSFW's Avatar
If it produced a 512k file, I'm going to guess that you actually have a 512k PCM. I don't know why else that would happen.
Can you try with a PCM that has a GM operating system on it? I don't have HPTuners, so I don't do any testing with HPTuners (or EFI Live or any other commercial tuning tools), so I can't guarantee they will play nice together.
Also please get Release 8, it does some extra validation after reading from the PCM, which might help explain what's going on.
Old Nov 26, 2019 | 02:45 AM
  #736
i420tom's Avatar
I assure you it's a p59, I'll give 8 a try and report
Old Nov 26, 2019 | 10:17 AM
  #737
Jrgunn5150's Avatar
In regards to scaling VE tables.
In my experimentation, I was attempting to scale a 6.0 VE table down to accomodate a 5.3 running a 4L80e, to get around segment swapping.
In HP Tuners I would just subtract 12% from the VE and use the 6.0 as a starting point.
Tunerpro seems to start at 0 and go up, and doesn't seem to accept negative values.
So amI going about this all wrong?
Old Nov 26, 2019 | 10:29 AM
  #738
NSFW's Avatar
Try a "quick compare" using a 1mb file, I think it will print the chip ID before it starts the comparison... Yours might have a chip that I haven't seen yet. I'm pretty sure there's an Intel chip that the app doesn't know about yet, for example. That should be easy to fix though.
Old Nov 26, 2019 | 03:21 PM
  #739
i420tom's Avatar
So far pcm hammer 7 with (new) read kernel produces a 512kb (not 1mb) file but it is corrupt? Last read block Recieved block starting at 520192
Also when trying pcm hammer 8 on this and another p59 pcm I have installed in another car I get same read error at the end on both. Does not save files but the last read block in the logs was
Recieved block starting at 520192 which is same as pcm hammer 7,
So it stops reading after 512kb. As 520192 start block read ends with 524288. 524288 is =512kb as 1kb is 1024.
I am for sure reading 2 different 1mb p59 pcms. But the read stops after the 512kb
Old Nov 26, 2019 | 04:16 PM
  #740
i420tom's Avatar
Just realized after browsing another forum that it is import to note that I believe both of these are intel f800 flash chip 2003? P59 Pcms.
These pcms are actually an oddball but also desirable p59 computers because they have the ability to control a cable throttle body with IAC.
Most of all the later P59s pcms cannot control the cable throttle as they are missing the IAC drivers on the board and are used solely for drive by wire electric throttle bodys
