Inexpensive Opensource Flashing(Read is 100% working)
You seem to be the absolute guru for the vehicle protocols from that explanation, and I didn't mean to seem like I was stepping on toes.. You guys have done "awesome" with the all the hard you have done.. I guess the only thing to do would be to get the rest write capabilities done and leave it at that.. lol
Especially if you've got the AMD flash chip, but if you've got the Intel I'd still like to take a shot at it.
Since a OS flashing has a little bit higher risk, I'd recommend doing it with a bench harness.
Thank you again
Also, just FYI, the OBDLink LX is considerably faster than the SX. In the US, the prices around $50 for the LX and $30 for the SX, and I think the extra $20 for the LX is money well spent.
The ELM327 will connect via PCMScan so fairly sure the cable and test harness are working....although oddly for an ecu powered up with nothing connected, it shows no fault codes. Which strikes me as odd.
The OBDLink LX you refer to is a wireless bluetooth module ? Not a USB ? Just for clarity. And are these generic ? ie must it be from Scantool or China ? lol Although TBH, it does look like the genuine thing is cheaper.
OBDLink MX or MX+ ?
OBDLink MX or MX+ ?
It is a Bluetooth device that works on Windows(assuming you have BT on the computer) and with Android. It has a much larger buffer then the OBDLink LX that is USB.
I don't see a read or write buttons,"Read Full Contents, "Modify VIN, ect.
If someone could lead me in the right direction, I would greatly appreciate it.
Thanks you.
Thanks you.
This is what your screen should look like:
What version of widows are you running this on BTW?
