Inexpensive Opensource Flashing(Read is 100% working)
Old Jul 15, 2020 | 05:38 AM
  #861
johntorg's Avatar
I agree that I won't be able to use it. Now I need a good Bin file. Engine is a 4.8 with headers and an LS1 intake and throttle body. Pistons are flat top, so compression may be a little higher than stock. Not sure about the cam, but has trunions installed on the rockers. I am looking for a good starting point with an OS that has a detailed XDF available. Any suggestions?
Old Jul 15, 2020 | 09:56 AM
  #862
ALL 4.8 pistons are flat top. They are used to gain compression in 5.3's using stock parts.
Old Jul 15, 2020 | 07:58 PM
  #863
B52bombardier1's Avatar
What transmission? I have several BINS here with richly featured XDF files for 5.3 L engines and 4L60E transmissions. A 4.8 L engine is tougher for me to assist you but perhaps not impossible.
Rick
Old Jul 15, 2020 | 08:03 PM
  #864
NSFW's Avatar
For the 1mb PCMs, 12587603.
For the 512kb PCMs, 12212156.
Old Jul 16, 2020 | 06:11 AM
  #865
johntorg's Avatar
The Transmission is a 700R4. Injectors are new, so I guess I'll. have to check the size..
Old Jul 17, 2020 | 07:05 AM
  #866
johntorg's Avatar
Default Next steps.
I have downloaded 12212156 and a working XDF file. I have a used 09354896. I will use PCM Hammer to upload and save the Bin that is on the PCM. I would like to defeat the security and test run the engine. The bin I downloaded is for a 2002 5.3 truck. The engine is a 4.8 with LS1 intake. I will use TunerPro to modify the Bin and write it back to the PCM with PCM Hammer. This will be the first time I am doing this. Any comments or warnings will be appreciated.
Old Jul 17, 2020 | 04:26 PM
  #867
johntorg's Avatar
I re-read the PCM and now PCM Hammer says it is good. In the last upload it showed as bad. Start End Stored Needed Verdict Segment Name
[04:33:56:596] 00000 7FFFD 2FD7 2FD7 Good Operating system
[04:33:56:612] 08002 12DFF B8A0 B8A0 Good Engine calibration
[04:33:56:612] 12E02 169FF 9B84 9B84 Good Engine diagnostics.
[04:33:56:612] 16A02 1B9FF 8806 8806 Good Transmission calibration
[04:33:56:627] 1BA02 1C2FF 59F3 59F3 Good Transmission diagnostics
[04:33:56:634] 1C302 1D07F 3146 3146 Good Fuel system
[04:33:56:634] 1D082 1D9FF A536 A536 Good System
[04:33:56:649] 1DA02 1DAFF 0CB0 0CB0 Good Speedometer
The OS number still comes out wrong in TunerPro. I guess I had a data error when I read it the first time. since the OS number is invalid, I remain unable to find an XDF file.
Old Jul 17, 2020 | 05:01 PM
  #868
PM me and give me your email address and I will send you a good XDF file for 12212156. A file with "xdf" is not an allowable extension here.
Rick
Old Jul 18, 2020 | 05:40 PM
  #869
NSFW's Avatar
What is the OS number that PCM Hammer displays after you click "Read Properties" while connected to the PCM?
Old Jul 19, 2020 | 06:42 AM
  #870
johntorg's Avatar
The OS number is the same in PCMHammer. 1273010 I found a reference to it on the HPTuners website So it is valid. I will try to read it with a friends HPTuner system. If anyone has an XDF that will work with this, it would solve my problem. Right now I am starting over with a .5.3 file and trying to get it working with 36lb injectors etc.
Old Jul 19, 2020 | 06:57 AM
  #871
I wonder if that oddball numbered OS is a custom operating system for 2-bar or 3-bar that somebody squirted into your PCM? Custom maybe from HP Tuners or EFI Live . . .????
Rick
Old Jul 19, 2020 | 06:24 PM
  #872
johntorg's Avatar
HPTuners shows it as a 1 bar OS, but seems to have 2 and 3 bar versions. I want to read the injector tables to get a good starting point for modifying a stock BIn. I currently have a
.4.8 LM4 12208322 Bin Running
Old Jul 22, 2020 | 11:19 PM
  #873
Stampede4ever's Avatar
Does anyone have a good OS, and XDF file for a p01 pcm? Going to try this again.
Thanks.
Old Jul 23, 2020 | 12:27 AM
  #874
NSFW's Avatar
Thanks.
12212156
You can find both files at
https://github.com/BoredTruckOwner/L...ine_Repository
Old Jul 23, 2020 | 08:55 PM
  #875
Thanks.
Old Jul 23, 2020 | 08:59 PM
  #876
Try this:
https://github.com/BoredTruckOwner/L...r/.XDF%20Files
Rick
Old Jul 23, 2020 | 10:56 PM
  #877
Then what? I can not download the file, maybe the wife is right about me.lol.
Thanks.
Old Jul 24, 2020 | 07:19 AM
  #878
That link used to work. Send me a PM with a regular email address and I will send you a good XDF for 2156.
Rick
Old Jul 24, 2020 | 09:14 PM
  #879
MudDuck514's Avatar
Hi all,
I just downloaded the XDF.
Link works - right click & use the save as option.
Mike
Old Sep 1, 2020 | 04:43 PM
  #880
Is there a reason when I installed the 12212156, it does not have any listing for vats?
Thanks.
