Inexpensive Opensource Flashing(Read is 100% working)
I've got maybe three hours of work here plus my time wandering the junk yard which I regularly do anyway. There's probably a company that sells something like this harness and it should not cost a lot.
Rick
http://www.gmtruckcentral.com/articl...h-harness.html
I didn't bother with the switch, and all of my electrical connections are just wire nuts with everything zip-tied into a single bundle as a strain relief.
The 12v power supply is just a wall-wart that I had sitting around, I don't even know what it was for originally. If you search for "12v wall wart" on Amazon there are a lot of options. I don't think I've ever seen the PCM draw more than 0.8 amps but with 512kb PCMs (P01s) I think I'd go with 2A just to be sure the voltage doesn't dip when the PCM puts the flash chip into write mode. With 1mb / P59 PCMs, 1 amp should be plenty.
I got my OBD2 connector from Amazon as well.
When I connect a basic OBD2 scanner, I can read and reset problem codes, but can't pull up the VIN. Do I need to write a VIN to the PCM? If so do I use the vehicle VIN? 94 Corvette? Can I do that with PCM Hammer?
Can I delete VATS with PCM Hammer, if I decide to use the 2000 SS PCM?
I have another PCM from a 2000 Camaro SS with the same hardware number. Some of the other numbers are different can I interchange them? Pictures are attached.
From the 4.8 Engine in the 94 Corvette
From a 2000 Camaro SS
That picture is of what we call an "896" PCM - last three digits of the Service Number. It is a 512k byte PCM that should accept any 512k byte operating system. I would make a copy of whatever OS is in there now and store it but you should be able to load any 512k byte file after that.
Edit: Whatever OS you edit must have a matching XDF for the OS about to be written . . . not an XDF for whatever OS is currently in the target PCM. Basically, you are about to overwrite and abandon the old OS in the target PCM. PCM Hammer or Tuner Pro RT, for editing, this requirement is the same.
Rick
Using Tuner Pro RT, open the BIN you wish to modify and open the matching XDF file that goes with it. Immediately, use File, Save As and change the name of the BIN so that you are leaving your original BIN unchanged. Don't change anything related to the XDF - it stays like it currently is.
Then, as directed in post 836 above, use the "Function F6" key Parameter Tree view and come down to "Idle", then "Table B4603" and make your idle RPM changes per my description above.
Save your BIN file often. Once you get what you think is a usable file, write it to the PCM. But remember, the XDF does NOT make the trip into the PCM with your BIN. The XDF is merely a definition file to help you view and edit what is inside the BIN. Never change the XDF.
Once the BIN is written into your PCM and you can at least start your engine with the RPM you wanted, that BIN file becomes the basis of any future work to the BIN you desire. However, do the File Save As thing again so that you ALWAYS PRESERVE your last good running BIN file. Be methodical and deliberate here to always leave yourself an Ace-In-The Hole BIN that runs so that you can flash it back into your PCM. You are going to make mistakes but don't blow your foot off here by ruining your previous known good running BIN. Go slowly here and creep up on perfection delicately until you know what you are doing. I'm still very much at this stage.
If that really is an 896 PCM then give it a try and write your 512k byte file to it. You have zero to lose here because, IIRC, that PCM is a spare for you that won't leave you walking / unable to start your engine as long as you keep your original PCM unchanged.
Speaking of spare PCM devices - I have three P01 512k devices plus a lab rat 1 megabyte P59. I pick them up for $18 on Half Price Sale Days around here and experiment with them at zero risk of leaving me with no good PCM.
Rick
Now I want to upload the Bin from my PCM. I have an OBDX Pro VT, which doesn't show as supported by Tuner Pro. I need very basic instructions on how to upload the bin file. If the OBDX interface doesn't work with TPro. What software can I use with it? It is the cable only version, apparently not supported by LS-Droid.
I think I figured out that I can use PCM Hammer to read and write the Bin and TunerPro to edit it.
Remember - it is unlikely that you will have a BIN coming out of any stock, original PCM you possess that will also have a matched XDF available for your use in editing. Possible? Yes. But there are many more GM BINs out there that nobody ever took the time to make an XDF for use with. It really only boils down to a small handful of richly featured P01 XDF files and precisely one P59 XDF file. Thusly, in all likelihood, you will be completely abandoning whatever BIN was originally inside your PCM though I do save those off and store them in case I might ever want to restore that BIN for some oddball reason.
Most people leave the OS number embedded in the file name of the BIN. If this is not the case, you can find the OS number using Tuner Pro at "System, Calibration Segment Information" - looking at Parameter Tree View.
Rick
I won't do any updating until I can do it on a spare.
I can't find that OS number anywhere. Could it have been scrambled in some way?
Rick
I don't know how it works with LS Droid, but with PCM Hammer you just click the Read Properties button.
Using Tuner Pro to get the OS ID has a chicken-and-egg problem. You need the XDF for the OS before you can be sure you're seeing the right OS ID. But in order to choose the right XDF, you need to know what the OS ID is.... That's why you need to start by using an app to get the OS ID from a live PCM. Then you can search for the XDF for that OS ID, and then you can be sure that Tuner Pro is showing the correct OS ID.
I'm pretty sure the XDF you're using now is not the correct one for the OS that you have. The numbers it's showing just don't make sense.
[06:53:50:271] Start End Stored Needed Verdict Segment Name
[06:53:50:290] 00000 7FFFD 2FD7 869A BAD Operating system
[06:53:50:294] 08002 12DFF B8A0 B8A0 Good Engine calibration
[06:53:50:300] 12E02 169FF 9B84 9B84 Good Engine diagnostics.
[06:53:50:306] 16A02 1B9FF 8806 8806 Good Transmission calibration
[06:53:50:315] 1BA02 1C2FF 59F3 59F3 Good Transmission diagnostics
[06:53:50:323] 1C302 1D07F 3146 3146 Good Fuel system
[06:53:50:332] 1D082 1D9FF A536 A536 Good System
[06:53:50:341] 1DA02 1DAFF 0CB0 0CB0 Good Speedometer
[06:53:50:351] This file is corrupt. It would render your PCM unusable.
Rick
